Ford coupe
s there an easy way to instaLL A MECHANICAL OIL PRESSURE GUAGE ON MY 272 VICKY ENGINE AND KEEP THE DUMMY LIFHT AS I DONEALLY TRUST THE ORIGINAL AND DONT REALLY KNOW MY OIL PRESSURE /
Yes... in line with the current sender there are 3 or 4 more ports on the block that you can connect a mechanical gauge to. ...
Yes - in line with the current sender there are 3 or 4 more ports on the block that you can connect a mechanical gauge to. Or you get get some fittings and have the stock sender and the tube for the mechanical gauge at the one spot Also could rig up an electrical oil pressure gauge the same way.
There are 3 or 4 more ports on the block that you can connect a mechanical gauge to. ...dmsfrr
37 Coupe, I believe that's correct. The fitting next to the coolant drain valve is the original location for the '55/'57 T-Bird oil pressure switch... see photos below.On the picture is this where the electric sender is usually installed or as factory installed? On my '55 T Bird 292 the tapped hole above coolant petcock is where mine is and where I installed "T" for original sender and mechanical oil pressure gauge. I think mine is correct because that was where the Casco sender wire fit but no farther.
I noticed the exhaust in that area, and we think alike. I have a copper line for my gage, not a plastic one.
I plan on routing both the copper tube and the electric sending unit wire through a "heat barrier" tubing (don't know what the technical word for it is) to help with heat issue.
