Unless you have a pressurised system , there is no oil pressure .
A stock engine will only show about 4 pounds .
There is a plug on the side of the block above the oil pan , below the valve cover .
In my opinion its just something that could leak .
Looking at oil pressure gauge and the kits I've seen do not really state the installation process. One might guess the pickup (at the engine) is some where in the valve cover --maybe? Anyone install one?
Many thanks,
-Mike
Cleveland
Actually, very comforting for me AFTER I added the oil filter. Before that, the hot pressure was essentially zero except when revving the engine. After installing the oil filter kit, the gauge reads the pressure INTO the filter so there is about 4 PSI (hot) when going down the road. Nice to look down and get the assurance that the pump is working.
sd
I have one in my car. It reads anywhere from 1/2-2 psi when warm. It really just helps to prove you've got oil. Hookup is easy. You can buy the sunpro gauge hookup kit, all you will need other than that is the fitting that screws into the block. The kits do not provide them. I bought the official kit from Macs and it was the basic sunpro kit with their sticker over the brand name. Would have been nice to know since I could walk over to autozone and buy the same one without paying shipping and their markup.
How would it hurt? Its just a bolt on item, its not like your greatly modifying the car just to fit the gauge.
No, the sunpro is the install kit. I have an original 1926 New York gauge co. gauge. Only reads up to 10psi. You can run the Mr. Gasket fuel pressure gauge though. It actually screws directly into the block if you don't want the gauge inside the cabin.
Its not that a modification would hurt. Its the small amount of oil pressure that the gauge would register on the model A. I wonder how many people that bought an oil pressure gauge called the seller with alarm about the 3 to 5 lbs. pressure that the gauge registers. Prospective buyers may not understand about the gravity and dip oiling system. Many would exp[ect it to idle with 45 lbs. pressure like some newer vehicles. Try explaining something to a person who probably thinks that they know more than you. Especially if you are trying to sell them a car that shows practically no oil pressure. I would rather just remove the gauge than try explaining to deaf ears.
