rbullockv8
I didn't get any response to this on the V-8 Forum, so trying here. This is for my 32 Roadster Pickup. Hoping someone can shed some light.
I had my Model B engine rebuild years ago by Phil Andrews in Ojai, CA. He told my to add an oil pressure gauge to the full-pressure oil/filter system he installed. I'm sure he told me where to add it, but if I wrote it down, I don't know where. I've lost touch with Phil--I believe he moved--so I can't ask him (unless someone on FB knows how to reach him).
The mounting block he made to hold the regulator and filter mounts in the original B motor fuel pump holes, which made it necessary to add an electric pump.
So my question is, which line does a Tee go in to connect the oil pressure gauge line? I'm thinking it is the one that comes out of the base of the regulator and into the timing cover. Anyone have a full-pressure system? Thoughts?
