If the integrity of all parts is good, you do not need an inner gasket. Using one may prevent the capturing nut from fully compressing the connection.
The crush washer and nut completely seals the fitting if installed correctly.
Again Tommy, which book?
I am using the 54/55 Shop Manual. I will report my results once I get everything back together. Thanks again.
