Lowell Fast
I want remove and clean under the dipper tray in the oil pan. Is there an easy way to remove the dipper tray?
If you plan to drop it on concrete, put down a sheet of plastic. MAKES CLEANUP lots easier. Probably a good idea on your grass also.
https://oldcarroadtrip.wordpress.com/2013/04/28/dropping-the-pan-cleaning-painting/
I am not a fan of the "slam it to the ground method". Try using the "push with your feet and pry with a baseball bat" method. The link above is to my blog from when I removed the pan on my engine.
