I don't know what the oil pump has to do with your drain plug problem.
Synchro, not referring to your post. I'm responding to the original poster #1, as he can't get the drain plug to come out of the oil pan bushing. Your post is correct too, for the dropping of the oil pan for the repair of the initial problem. He's got to get the oil out first.
I proceeded to change the oil on my 31 model and the
bolt spun in the circular bushing. No leaks
at this point but suspect I will have to drop
the pan to correct this. I read there was a tool
Mike's affordable sold to aid in holding the
oil pump, would this be useful?
I made a couple of them several years ago and they work well.. Very simple to make and cheap. You can get all you need at your local hardware store. Get a pipe plug that fits the hole (I forget the size), drill a hole through the center, thread the hole for a small machine screw. This makes the tool for maybe under 50 cents.
