Lee29coupe
I just replaced my oil pan gaskets and have a moderate leak where the back of where the oil pan wraps around the rear main oil seal/oil pan surface. I an pretty sure that it is a small gap where the rear main flange gasket and oil pan meet at the corner of the two. Anything I can use to stop it up? Maybe small chunks of cork gasket and gasket sealers mixed and coat around edges where leak is or shove some inside gap.Anyone use the Liquid Steel putty to plug up hole, maybe even super duper tape they show on tv? I don’t know if I can get clean surface to make something stick gap or cover like tape with oil film. Running 1/2 quart of oil lower seems to stop it when engine is not running but will dribble out when engine is running. Engine never leaked until I replaced gasket after taking a look at inside of engine when I removed it to mess with motor mounts, it,s not a big leak just a pain.
