bogiediver
As to not hijack the 'Oil Pan Leak' thread...
I searched "oil pan drain" and "oil pan removal" and got 2 threads on each search related to my question, but not completely answering my questions.
When I replaced the oil drain plug after the last oil change - the insert the plug threads into started to spin.
So - my questions:
1) Do all 'A' oil pans have this insert the plug threads into, or was this a previous repair?
2) Does the oil pan have to be removed to stop the insert from spinning?
-- If yes - any tips to make pan removal and replacement go well? Specifically with the 4 piece cork gasket...
3) Best method to permanently stop the insert from spinning either with pan in place or removed?
Thanks in advance
So - my questions:
Thanks in advance
