Oil pan cracks... fixable?
chambies
During my diamond block build up I noticed these small crack in the oil pan pocket where the from seal goes. Are these cracks a big deal? Is this common? Any thought on a good fix or repair???
Thanks in advanced.
Are you sure they are cracks? Looks like the seam between the inside of the seal channel and the outer pan stamping. Give it a closer look. Doesn't look like a problem. I recently used a one piece seal there and regret bothering with it as the pan removal is made more difficult. Not good! Fred A
Quite honestly, they will be fine if left alone. The seal is on the forward side of the cracks which should stop the oil from exiting the pan.
