I just did the pan on a 350 Chevy, same principle. I used some silicone RTV under the side rail gaskets and glued them to the block and let them set up. Dropped in the neoprene end seals, backed that up with a wipe of silicone RTV. Let that set up. I also put a few studs without heads along the rails into the block so the gaskets stay put.
Add a little RTV to where the rails and end seals meet, then drop the pan on. Take my time and get the pan bolts started, watch the corners of the rails/end seals. Everything hand tight, then torque it up to 6 inch-lbs. I find something else to do, come back to it after an hour or so, torque to 9 inch-lbs. Same thing, let it sit for an hour. Then the final torque. The composite gaskets I used will compress and then relax.
I have about 500 miles on the build and the pan is dry.
