Steve in Tampa
can a model a splash pan be used in a model b oil pan, in a model B engine with a counter balanced crank?
Could using an oil pump splash shield with the original height rod dipper tray (not lowered 1/8"), and trimming 1/8" from the oil pump splash shield for required clearance be possible for a bit mere oil control? Maybe not as much control as with the ford setup but some none the less. And running the oil level midway on the dipstick. Is there any documentation how successful fords changes to the lowering of the dip tray and addition of the oil pump shield were lowering oil consumption? Not considering the piston ring changes also as part of the equation.
