Oil pan 59AB photos
Thank you so much for the photos JSeery, have the same lines and holes, that I have been drawing.
If is possible yet, can you take a close-up of the areas that I marked?
Thank you very much.
All the best,
Jorge
See if this is what you are looking for. PM me your email address and I will email back the original higher res photos (around 4Mb)
59a and 8ba cams rotate in opposite directions, so the teeth on the gears would be in the opposite direction. The crank gear and the cam gear are matched sets.
Simply not true! 59A and 8BA cams turn the same direction. Only the cut of the gears differ.
So it is only the diretion of the teeth gears correct, I need flip over the both gears teeth?
Thank you so much by the notice.
JOrge
Thank you so much Ronnie by the notice and the photos too.
As I don't know of any existing engine near me not always it is clear, my support it is photos that I found in my searches or some help from the members of the forum.
Now i believe that is correct, the left that i have, the right it is the new one.
The engine that I have been designed it is the 59AB.
Thank you all for the help :)
All the best,
Jorge
Sorry about that, not totally awake on that one!!!!! The thrust of the cam is reversed, not the cam rotation. The 59a thrust the cam toward the engine and the 8ba thrust the cam toward to cover because of the cut of the gears. Some days are better than other!
Great work that model is really neat! Would you share a .step file of the 59AB intake manifold?
I would love to 3D print one for my desk!
Jesse
