I used plastigauge. I would get about 2.5 thou with the plastigauge, then remove one shim and it would lock up the crank. Since I'm new to "adjustable" bearings, I have since been wondering if perhaps it was "pinching" on the sides where the cap meets the rod causing it to bind a bit when there was still a bit of clearance on the top/bottom???. I don't know if they wear that way or not, just trying to find a reason for what I experienced. I did remove at least one shim from every journal (rod and main) IIRC so it MUST be better than it was.Yes that oil issues is puzzling but there IS a logical reason, just have to find it.
