I replaced oil pan gasket and bottom rope seal. I’ve had a leaky steering box, it’s a coupe so I just top steering oil off before I drive it. Steering shaft is a pain to remove on a coupe so i added it to the to do list. At first I thought it it it was the oil pan gasket but on closer inspection it was the oil from steering box. Oil leaks can really fool you. The valve cover is a very common place for leaks that are sometimes so small to catch unless you keep wiping and looking. Another oil leak was the bottom oil return tube mount on the valve cover, bolt mount was cracked , so small could not see it at first, some time the bolt was tightened and the bottom of mount bracket was cracked making it not seal. If it is an oil pan leak let it leak till it stops, note where and fill back up. Let it leak down again then mark that on the dip stick, that is your new oil top off mark. That’s how the old boys did in the day did it, as long as there are a few quarts in the oil pan it will not affect oil feed, the oil pan is just a bucket to catch and hold oil. Check it often and change it a little more often due to less oil in reserve to dilut dirty oil. Never admit a leak is yours, just for self esteem and blame it on the other guys leaky “A”. Watch out for EPA and a depends works good if you want to hide leak for a show or tour. Good luck and have fun!
