While I have the motor out (30' Town Sedan) to balance the flywheel and pressure plate, I thought I would trace an oil leak that was perplexing me. It turns out that the oil is coming from the rear camshaft bearing hole. Aside from some permatex on the gasket is there anything I should do to eliminate this oil leak? Anything I should be aware of that would cause this oil leak?
As always,
Thanks for your time,
Chris
As always,
Chris
