barkleydave
While doing brakes on a 31 Slant I noticed a pesky oil leak. Oil is leaking on the right front of the engine in the area of the timing cover and running down the splash pan. No oil is on the left side of the engine pan bolts or pan.
Is this a major chore to replace timing cover seal and possibly the crank seal? Less Andrews book provides little help with this.
Thanks
Thanks
