Houston Rodder
My Fordor Sedan has an oil leak that is getting worse. The leak is very bad right after the motor has been run and slows after it cools off. What are some typical types of oil leaks these engines develop? I am wanting to have everything I need to fix before the vehicle is tore down although I realize it is impossible to know before pulling the pan. Besides a pan gasket what are some pieces I should inspect or replace with the oil pan off?
Thanks
Thanks
