BILLF/TRF
A few days ago I appealed to you about solutions to fix a rear engine oil leak that appears to be dripping out of the hole in the bottom of the flywheel housing and around the bottom edge of that housing. I received many good responses after which I decided to let it drip and keep an eye on the oil level this summer. Well, after a short ten mile run, the garage floor puddle has increased in size to about 12-14 inches in diameter. I can't stand the site of that spill, am worried about a possible internal problem and have decided to pull the engine and look for the source of trouble. I would again like to ask for any advice on what may be causing this leak and in making sure it does not happen again. Thanks again!
