Thomas Sargent
Awhile back I installed an overflow plastic tank on my 1940 ford Four door flathead. System works great, system is still no pressure, but overflow tank allows me to completely fill the radiator and has prevented spills. The tank is semi clear white plastic. I have noticed a very small amount of oil film on the top surface of the coolant in the tank. After about 4 months of service, I removed the tank and cleaned all the oil film out. A few weeks later I notice the oil film has returned. Do I have a failing head gasket or is there a crack somewhere in the block allowing this. Amt of oil is very small and not causing any issues. NO sign of coolant in the oil pan. Thoughts? Thanks
