aussie merc
can anyone tell me the oil height in the sump or how far the oil level is from the sump rail as sticks and tubes are notoriously inaccurate
5" from the top of the oil pan. Which is 1/2" below the radius part of the pan.
It is 2 1/8" from the underside of the pan to the top rivet on my dipstick casting and the FULL mark is 4 7/8" below the casting with tube removed (remember it is at 45deg.).
Measure the outside of the tube (screwed in) and add 4 7/8".
again don't just dump 5 quarts in and hope for the best there are several documents in the service notes in regards to sump capacities /oil height and pickup clearance and they state that pickups must be correct to the sump. Pickup to low or close to the pan bottom will induce oil starvation by starving the pickup of oil and to high will result in it sucking in foam and suffering from oil surge . Oil capacity will control the change intervals .If i can find these docs will post here may take a few days .
