Never even heard of that motor! i have a feeling it is not only because of the way it performs, definitely not a high winder. the motor is revving pretty high at 50mph and running out of power, at 60 mph it feels like it is going to blow up! It feels like it is geared super low and needs another gear.
Great link, thanks. I have actually read most of these links!
My car is a 36 with no exposed driveshaft. I know how to check it on a normal car where you can mark the driveshaft and count the turns vs the tire turns to get the ratio. How do i do it on this car? I did not see anything marked on the rear, but wan't really looking for itThat's just flatheads, it's not turning near the rpm you might think it is. Check the gear ratio and see what you have in it, but I would guess it's not that low of a rear end.
The rear axle should be marked as to the original gear ratio. If not, it is fairly easy to check.
You got my vote on this!lets get back to the question do i need an oil filter my answer is hell yeh ive spent 45 years working on anything from a chain saw to a V16 mine truck and simply if you haven't got a filter of some sort you've got no hope of catching any contaminant
