I agree with the posters above. Of the readily available kits, I use and install Mike's A-Ford-Able on engines I rebuild. Mike's kit, filters most of the oil the pump moves...far more than the side timing gear cover kit. The filtered oil is delivered to the same area of the valve chamber floor as a stock system.
Dick, The increase in pressure you are noting on your oil pressure gauge is from the resistance of the oil going through the routing pipe and the filter. The flow is not greatly reduced if your oil pump is in good to new condition.
I run a filter on the driver (Phaeton) shown in my avitar. I have over 50,000 miles on this engine and it still shows no sign of fatigue. I change oil every 2500 miles and do not need to add oil between changes. I have not had the pan off the engine since the rebuild...the filter has to be a contributing factor.
Good Day!
Dave in MN
