Oil filter
1942 f1
I posted a while back about the return line on a 39 model motor, had several responses on this including a banjo bolt on the fuel pump stand. I cant find one that will work,but i saw a intake that had a plug on the fuel pump stand,right beside the glass bowl on the fuel pump. I have a aluminum intake that has the same fitting in it. Is it possable to return the oil to the motor on that fitting,thanks
I recall your original post as it turned out you were not concerned with authenticity.
So, that being the case, you can return the oil anywhere you'd like. Being returned through a fitting in the valve chamber cover would certainly be a functional method.
Thanks for reply,I have looked all over for banjo fitting with no luck. This looks like the best option for me now. Thanks again
