Oil filter question - Kenz adapter
JayJay
The Kenz oil filter adapter reportedly came with Motorcraft FL-1 filter. That filter is apparently no longer available, but FL-1A shows up. Does anyone know the difference between the FL-1 and the FL-1A, and will the FL-1A work on the Kenz adapter? Or a NAPA equivalent? Thanks.
The FL-1A works fine as do the other manufacturers equivalents. I like the Wix that is shorter than the FL's since I have a 90 degree adapter on the original purchased from Bill Kenz adapter I have. There threads about it on here somewhere...
Best regards,
gb
The FL-1A is the same size as FRAM PH8A or WIX 51515. Napa Gold 1515 is a WIX filter with the Napa name on it. Paint it with some Ford Engine Green paint before you install and it looks a lot better.
I also like the Wix 51515, same as Napa 1515, or Fram PH8A. There are many brands that will fit. Fram PH16 is shorter but will fit.
Edit: Same as Sam says, I was typing and didn't see his post.
The following filters will fit:
Pennsoil - PZ-1
Fram - PH8A
AC - PF2, PF20
Motocraft - FL-1A3
NAPA - 1515
Lee - LF-2
Tom Endy
