MGG
Have you determined if there is a 1/16" restictor hole in the inlet fitting?
If so then the hole in the tube should be twice the volume (5/64").
If there is no restrictor hole anywhere on the inlet side, then the hole in the return tube appears to be acting as the restricion hole. (probably early design )
In the recent restoration of my 59A engine, I only found one outlet hole in the center pipe and no restrictor fittings in either end of the inlet line. I figured that the one hole was acting as the restrictor but I was nervous about it and added one at the canister. In the 1960's we drove the truck continuously with no problems, on the farm and around the county, delivering farm products.
