OIl Filter Canister, Coil Bracket, Plus ...
1950F1
Sequim
Wa
Looking for the following 8ba/rt parts:
1. Oil Filter Canister with oil lines if you have them. Canister uses seperate head mounting holes, not head bolts and has intake near top, not center of can.
2. Coil Mounting Bracket
3. Distributor Vacuum Advance line from carb to dist.
Please PM
Regards, Carl
I have 2nos lines both have the wrap around sticker on them. both have the banjo fitting on 1 end. 1 is 23" and the other is 24" long. $25 each. ken ct. If paul dont have any.The oposite end has an inverted flare fitting that turns for installation.[male one].
