My 30 Tudor was missing the oil drain tube on the rear main, which I believe is the primary contributor to the large oil leaks out the bellhousing. Not only was the tube missing, but so was a small chunk of the main cap casting where the tube threads in. It appears that there should be a vertical tapped hole that the tube threads into, and also a horizontal hole that is the end of the oil galley in the cap. The broken piece of casting would be the piece between these two holes. I'm left with half of a tapped vertical hole and half of a smooth bore horizontal hole. Should the horizontal hole be plugged? If so, with what? It appers that the end of this hole is too close to the drain tube hole to be plugged with a galley plug. Does anyone have a picture of this area of a rear main cap? Any info would really help me patch this mess up. Thank you!
