Oil drain plug gasket size/type
smross
I'm about to do my first oil change on my '37 coupe with a 59AB engine. What size oil drain plug gasket do I need and what material is used eg: copper, fiber?
I won't DARE ask what oil viscosity you guys use!
Thanks.
You need to determine which oil pan you actually have on your conversion since '35-'48 pans will work on a 59a engine and there are different size oil drain plugs used during these years. MAC's would probably sell the gaskets you need. I prefer the copper versions.
