Tom F OHIO
What is the correct spot for the oil to be on the dip stick. Is it center between the L & F or is it more toward the Full or on the F.
Thanks
Thanks
I drained my oil, added five quarts of fresh oil, and marked the dip stick
You may have too much oil now. When you drain the oil ~1 quart stays in the valve chamber and dipper tray. You now have ~6 quarts in the engine.
I found this out when I first bought my Town Sedan. After changing the oil she promptly let me know she didn't like this by leaking out the rear main seal.
I now run it half way between F and E.
... end the conjecture and misreading of the posts and others opinions.
