Oil Can
bobgreco
I have seen a few Model A's with an oil can mounted on the fire wall above the starter motor. I am curious if this was standard or an aftermarket item?
As always, thanks!
Bob
Oil cans were supplied with the early As as part of the tool kit until 5/28 per the JS. They are shown in the early parts book. As far as I can determine there is no specific clip with a part number provided to mount them on the firewall. The clips were either T carry over or an aftermarket piece. I have two different styles.
I'll add a little bit of oil can "lore" I read once. The Model-T oil can spout screwed inside the threaded portion of the can and the Model-A oil can spout screwed on the outside of the threaded part of the can.:D
Bob-A;)
Bob-A, that brings up a good point. I've heard there were supposed differences in the T and early A cans, size of script, etc, etc. Maybe Don Turley will see this and post. I was thinking of also contacting Gary Johnson about it as well. If anyone else knows anything please post.
thanks to bick for the photo
That is interesting about the internal and external threads because I have one of each and I was wondering what the difference was. The script is in a slightly different location also. I will post some pictures later today.
i believe the 'inside/outside' thread info came from one of Doc K's articles some time back. I copied the info to my files but did not include the source/date:(. FWIW
Here are pictures of different Ford oil can in my collection. Gary in MN
other than script, no markings on either can ... one on left has a light coat of copper plating
