Oil again
Ford coupe
Since Rotella has taken the zinc out of its oil what can I do with my 36 and 55 in which I used the Rotella..Cant come up with oil containing zink here in Canada so maybe I will have to add ZDDP but if so how much? Looking for abetter way forward and hope you guys can help..Also do I really need it???
Should be plenty of other brands around surely, what's Canada doing? I wouldn't obsess about zinc but you will need some, more so for your 55, just going to have to add the zinc...
If zinc is really all that necessary, how does anybody get by using non-detergent oil?? (especially for break-in, when zinc is needed the most?)
Valvoline VR1 racing oil has zinc. Most auto stores here in the US has it but don't know in Canada. Has Canada done away with all zinc containing oils?
I use Rislone zinc and phos additive in both my '47 and '84 in differing quantities as recommended by them.
I like 50fordcoupeman use Valvolene VR1 racing oil which does have enough zddp for flat tappet engines. I would just as soon not have to add something else to the oil.
See if you can find Chevron Custom Supreme oil in your area.
It's great oil, has a good amount of Zinc & here I can buy it
at Costco.
Just a suggestion
You just hush, flatjack! You'll spoil their fun. Don't confuse them with the facts!
A fact is that Phosphor and ZDDP is the best oil additives invented and only taken away because of catalytic converters.
You don´t need a crazy amount of it in a flathead but why not use an additive that works like a wearshield on your lifters.
Please tell me what is bad for the engine with using an oil with phosphor and ZDDP compared to an oil without them.
Each oil change I just add a bottle. I get it at the local NAPA store. A bit pricey.
the never-to-end-soon lubricants discussion (zinc/600w/corn head/WD-40/non-detergent/break-in and so on) always reminds me of weight loss supplements, health food products and armchair quarter-backing. Interesting perspectives, no end to solid advice and the occasional facts. And, ultimately no one is ever wrong.
