LBCD
I know this subject has been beat time and time again, but just maybe someone can chime in as my situation is a little unique
Around 8-9 years ago I changed to 12v and had my cluster in my 41 Tudor overhauled and the fuel gage worked fine with the original tank and sender. Some years after that I decided to put in a new tank and sending unit. I recently got the car back on the road and the fuel gage is reading empty with a full tank. The new sender is a generic type that I cut to size to fit my application probably purchased from Mac' or Sacramento vintage Ford I cannot remember. The bolt pattern for the sending unit on the new tank is a 5 hole application.... so the 6 volt sending unit that I assume I need that C and G carries is a 6 hole application.
The builder who I had rebuild the Cluster has since closed up shop and I am looking for him to answer my question.... But in the mean time I will ask here too.
1. How to tell if the cluster was changed for a 12v system? I'm assuming it hasn't being that it worked fine with the original sending unit that I removed along with the original tank. But you know what assume means
2. If I purchase the new unit (01A-9275) form C and G will I be able to just plug weld the five holes being it has six holes and redrill it making it a five hole application?
I did remove the new sending unit and hooked it up and moved the float to full...it would read full and then drop suddenly without moving the float down. ....then read empty.
Any and all help appreciated! Merry Christmas!
