I have the master helicoil repair set for 14 mm I tried the tap and it is too small for the hole.
Opps! I incorrectly read Pete's suggestion. Thanks for letting me know. Getting old is no fun.I believe Pete recommended EXTERNAL threads on the manufactured insert...needs to be "threaded" into the NEW hole...not "pressed". You knew that, though. DD
