1oldtimer
'47 stock flathead, with a msd pro billet dist, 6al box and blaster coil (12v system). it has a 2 jet on it now but had a rebuilt 94 (had the same problem with both carbs) and it has a steady stream from the accel pump. I have to make a timing set up for it to fully check it. it has a little bit of adjustment and i've messed with the springs and stop (no pinging now). question is would no vacuum advance cause this? should i look for a stock dist and convert to electronic. it acts like a bad accel pump, you give it gas, it starts to rev and dies for a second and picks up. i have to slide the clutch to get past it, once past the flat spot it runs great.....the other thing i noticed is it stumbles/bucks when your cruising in that spot (at part throttle).
