Got this in a lot of parts recently. The housing is normal but the shaft and impeller are quite different. The impeller is a completely different design with 4 blades and under it is a spring. Anybody ever see one like this before?
I have some that I got in a collection . They must have been after market . I have used one and it didn't leak , even though no packing or packing nut was used on these pumps .
Aftermarket replacement - may be a Ford replacement after Ford's development of the V8 pump (which the impeller resembles greatly.)
IIRC, the front bearing housing is "small" and contains only a sleeve type bearing lubricated by a grease zerk alemite style - which leads me to believe non-Ford source. Ford tried a sleeve bearing at this location for perhaps a month in 1928 and found it unsatisfactory.
They're around muchly and pricing is cheap. But replacement parts are not available and were probably not "in the day" either as one could buy the entire pump for small money.
