1939mars
I have posed this question to my club's tech advisor but I thought I would get it out in the wider world. I am doing a valve job on my '31 sport coupe. All new valve parts: one piece guides, adjustable lifters, reground C-spec cam.
I have the valve train in and have adjusted the clearances using the method in the Les Andrews book. Everything seems fine except for the 4th valve back. For it, when it is in the measurement position per the book, a feeler gauge will not go in. If I 'rock' the engine (rotate the engine forward so the pistons move about half an inch, then back to even with each other) I measure 15-17 thousandths.
Prior to rocking the engine, when the feeler gauge will not go in, I cannot move the lifter up and down or rotate it. After rocking it, when the feeler gauge goes in, I can both lift and rotate the lifter. When I rock the engine I cannot tell if the lifter or the valve is moving, but it does free up. Everything is well lubed with red line assembly lube.
A friend has suggested I try swapping the lifter with another one to see if the problem moves with the lifter. I am seeking knowledge before I start disassembling.
Thanks,
Scott
Thanks,
Scott
