I'm stupid when it comes to model B stuff.If you have trouble finding a condenser for this use a Model A condenser by elongating the hole in the tab at the end and using a short wire between the end of the condenser and the distributer. Be sure to buy a high quality condenser from a supplier like Bratton's. If I remember correctly there is a wire at the junction box of a Model A that works perfectly. As others have noted the timing pin is in a different location on the Model B timing cover so you need a Model B cover to go with the distributer or compensate for it in some other way.
Charlie Stephens
That's an odd looking spark plug, what is it? Is it in an adapter?
You can use the cap, rotor, bakelite body, cam (although the B cam was better), the shaft to the bottom and a lot of small parts. Of course the advance mechanism is unique. The points are unique and used to be hard to find. There is an excellent blow up of the distributer on page 504 of the Green Bible. The best source for knowledge and parts is Renner's Corner, (734) 428-8424.I'm stupid when it comes to model B stuff.
What else from model A can I use on this B distributor?
Champion W20?
Thanks Charlie. I appreciate the info.You can use the cap, rotor, bakelite body, cam (although the B cam was better), the shaft to the bottom and a lot of small parts. Of course the advance mechanism is unique. The points are unique and used to be hard to find. There is an excellent blow up of the distributer on page 504 of the Green Bible. The best source for knowledge and parts is Renner's Corner, (734) 428-8424.
Charlie Stephens
