OD solenoid
len
I have three 6 volt solenoids. Is there a way to bench test them to find out if they are good. Thanks Len
With 2 jumper wires hook one positive to case to ground it and touch wire connection screw to negative jumper and the pawl should go out about 1/2". If it does not remove the case bottom cover and file the 2 sets of points and replace cover and it should work if it is going to. Ron B.
