Here's wishing you a quick and full recovery! I've been following your posts on the roadster with great interest as I'm about to do much of the same to mine!
I was just showing a friend some of his work , hope you heal without to much problem! Bet that is the cleanest your hands have been in sometime with as much work as you get done!
Flop, I will send you my sawzall to remove that cast and a guitar to serenade the nurses and start the healing process. Looking forward to your post when you return. Take care, Mark.
Thank you everyone so much for all of your well wishes & good vibes. I'm home after 3 long days in the hospital with the addition of some stainless steel & screws in my forearm and 8 stitches above my eye. It could have been a lot worse, but I definitely my learned my lesson.
I should be out of commission for only a month or so and will be spending a lot of time on the HAMB/ fordbarn during my time out. Again - thanks so much for thinking of me!
Been praying for you. I remember how boring recovery can be. My recovery went from July 4th- Sept 8th when I was finally allowed to return to work on a restricted duty basis. It was not until early Dec. That the restricted duty was removed. July and Aug. seemed like an eternity. Nothing I could do in the shop beyond starting the Delivery Sedan and opening and closing the door. Boring to say the least. Find some things to occupy your mind even if you aren't allowed to do anything with your hands. Rod
