Nuts, Bolts and Screws - 51 Ford Coupe
msalamanca
Is there a list of sizes etc, I would like to use all new mounting hardware specially for the front end sheet metal.
There is a nuts and bolts warehouse a stones throw away from my work, and would prefer to use all new then reuse the old.
Thanks guys.
Unless there is someone who may have compiled a list while doing a restoration, Ford does not list hardware that way. You need a parts catalog ( text and illustrations ) for the part numbers and a Ford hardware catalog to determine the size. For instance, you need bolts for a fender. Some of the illustrations will show the hardware number for thye bolt, sometimes you have to look up the fender and at the end of the listing, you'll find the hardware needed. Also, sometimes the listing will give the size. If not, go to the hardware catalog and find it by the hardware number and it also lists the size and usually a pic of the bolt. I did Ford parts for 30+ years and this is the only way to find the nuts and bolts. Up until the last 10 years, most of this hardware was still available from Ford. I got alot for my 50 F-1 this way. But, no more. It's all metric now. If you don't have the parts catalogs, I suggest a set is a good idea to buy. Alot of good pics for assembly. Ebay is a good source for catalogs and the hardware catalogs.
Just checked the website for fordscript.com $150 for just the front sheet metal and radiator.
I guess the little things do add up *is this mic on? its a tuff crowd*
Roys prices are not cheap but his parts are right on, and a great guy to talk and work with. If you want the good stuff he gets my vote.
