nu-rex cut out
Zack
I'm trying to wire my 30 deluxe coupe and I have a couple of questions. I have a nu-rex cut-out and I'm not sure where the wires go. I have a wiring harness from Rhode Island but I'm confused as to what side do the 2 yellow wires from the light switch attach to? Bat or gen? What side of the cut-out does the single yellow/blk wire that goes to the drivers side terminal box attach to? bat or gen?
Does it matter which terminal on the starter I attach the solid yellow wire to?
I googled the cut out,suppose to come with directions,possibly they can Email you them,you don't want to burn it out.
Give Nu-rex a call and as rocket said have them send you the directions. They will tellyou the info but it's always good to save the official directions for the next owner.
There are only two connections to the Nu-Rex cut-out, Bat and Gen. The connections would be the same as the one you removed. The yellow/black wire from the terminal box would go to the Bat terminal. The two yellow wires from the switch block provide 6 volts to the switch and the horn. This, of course, assumes the rest of your wiring is correct.
Frank
