jeepguy1948
I have a Stromberg 97 with a clogged accelerator pump nozzle that even a sonic cleaner wont clear. I got a new set of nozzles put I can’t get the clogged nozzle out. What’s the trick to getting the old nozzles out?
THANK YOU, Glenn for that excellent pictorial solution.
Thank You for that very helpful post Glenn however that is not what I was looking for. I am trying to remove the accelerator pump nozzles. The part where fuel spurts out when the throttle is opened. It is only a press fit.
I managed to get the nozzle out eventually. There was no way to get a wire into the nozzle as it started in the bottom of the accelerator pump well. Once I had it out I could easily see that there was no way possible to clean it out while it was in place. I bought new nozzles which are now installed.
