Discovered when installing LED headlights that my single tail light ('29 coup) would not light. Checked the bulb filament -good; checked the bullet connection under the back Left fender- good. Took of the bail off the steering-column-end switch (on of Henry's poorest inventions!) to try to access the contacts. Could not separate ! Rewired the A about 3 years ago so that switch is almost new
Sprayed WD40 down the center and let sit over night.... No success. In desperation today took a spray can of Mass Air Flow Cleaner (closest thing I had to alcohol ) and sprayed thru the various openings and whatdaya know.... the bulb lit !!
Do you think I've damaged anything in that mysterious light switch ???
I do have an Oil Retainer Tube on the end of the steering gear ..
Thanks for your thoughts...
