Not sure this is a 39 Frame
"The serial number was close to where VanPelt says they should be on the other two locations"
Your above previous statement is what I'm trying to interpret.
Did you find the serial number in the other two locations as mentioned on VanPelts website, and if so, what is it??
Should be something like *18-X,XXX,XXX*
When wire brushing the frame to find a serial number, I would suggest using a hand held wire brush to carefully remove the paint and/or rust over the numbers, and occasionally wipe with solvent on a rag. Using a wire wheel mounted in a power tool could completely abrade those stamped numbers away very quickly.
