RCM
...just a dumb one:
The wipers on my 56 Customline only go half way and dont come down unless I turn of the switch.
I'm gonna go with the brake fluid lub job. I already read about it here and on the HAMB.
I was trying to avoid the disassembly and do it on the spot. I already got a new rubber hose to replace the one that goes from the fuel pump to the vacuum motor since the one ive got is hard and dried out causing possible leaks. I also hope that I get fortunate enough to solve the problem I've been having with the engine dying on me whem I come to a stop (at a red light for instance) - I also read about hambers and barners with the same issue that had a vacuum leak.
What I'd like to know is if I have to disassemble the unit to replace the hose or can I otherwise pull it off through the firewall.
Help appreciated.
Thanks.
PS - My wipers dont suck!
Help appreciated.
Thanks.
