If you want to prove this to yourself, get a 650 Yamaha twin and remove the stock mufflers and just run the header pipes. It will run like krap till you put the mufflers back on and introduce back pressure into the exhaust. Almost any twin cylinder motorcycle will react this way without back pressure as will the inline fours.
Backpressure is needed on engines that have "tuned" exhaust systems. Often times with high performance motors the exhaust system is a significant part of getting the high performance from the motor, but, lets not regard the Model A standard motor as a "high performance" racing engine.....
Also, with the tuned motor the performance is limited to specific RPM values.
Smokey Y. wrote a great book in the past about the methods used to tune the motor, I really do not think that this is relevant for the Model A !
Marc
First, Tom and George, the 2 strokes do not use exhaust back pressure they use sound waves to control the cylinder scavenge. This is why the muffler is shaped like 2 cones welded together at the big end. I found out how to tune 2 strokes running them back in the day. We used to make our own stingers to get the best performance from the 2 stroke racers.
Second, the reason a pietenpol runs good is the carb is tuned to the engine without exhaust and the engine is mostly run at a steady speed not up and down like a car. If you run the throttle up on any motor without a muffler or with straight pipes slowly it will respond without problem. It is when you stab the throttle that it hesitates and splutters.
I don't think the problem with this motor is back pressure because even a straight pipe with a bend would present enough to make it run OK.
YOU RANG??---"Country road take me home, to the place-----where Momma's working up Beans & Hamhocks & Cornbread & Poke Salad Greens & Buttermilk, cooled in the well, & Chief & the Kid's finishing up that ooold Green Tudor"!What ever you say James I'm just a dum country boy.
