cbillelder
Hi Guys-
I recently found a pair of new old stock Trico vacuum wipers for my '38 coupe. They are new in the box but both are stuck. The shaft won't turn. I don't want to force them and risk breaking them, so I need some expert advice on these. I know it seems to be a common problem when they sit for a long time (years) and the grease gets hard. Is there any way of loosening them up short of opening them up? If I do open them, what is the best grease to use for lubrication and is there a source for replacement gaskets, or am I on my own? If it helps, the part numbers are KSB389-1G and KSB390-1G.
Thanks, guys. Any advice you can give is much appreciated.
Bill
cbillelder@comcast.net
Bill
