wunderwerks
I picked up a distributor today at a swap meet that I cannot figure out. It was in a Ford Motorcraft box with a label DA-691, C50Z-12127-E. It is a dual point with a steel plate screwed in place of where a vacuum advance would normally attach if applicable. In very light lettering above the mounting base you can read E2AE-12131-DA.
It is obviously brand new and I'm certain it is Ford manufactured as 12127 and Motorcraft are cast into the outside top of the distributor just below where the distributor cap sets. The distributor does not have the single stud that locates the distributor cap in the correct position. It does have two larger studs 180 degrees from each other located 3/8" below the top. A period correct distributor cap for a SBF of the mid 60's will not work. If this was a replacement distributor for the original dual point HIPO, what distributor cap would be used? What do I have?
