Nors
23ford
tulsa
Ok
Price
varies
My dad had a garage and closed it in 1968 we are now going thru the inventory and listing it for sale. Prices are reasonable. He was an Autolite Wholesaler also, so a lot of new Autolite inventory in the boxes.
point sets
condensors
dist. caps
rotors
brushes for both starters and generators
ac clutch
plugs
heater switches
lots more
prices start at 1.50
Please call us and let me know what you are looking for and we will look for it. Hope to have a list soon.......call 5pm to 11 pm central time zone
9 one 8 four 2 five 6892
shipping is actual cost.
Thank you for helping dad out.
MFG Part Number Notes Qty Delco condensor A-201 Willys 46-52
Delco condensor D-204 GM stude 50--65
Delco gen brushes D-704 58-62 60-63 GM
Delco condensor D-203 chevy 2 covair buick spl rambler 6 2 Delco points A-113p open box 59-61 chry desoto dart lancer 2 Delco points D-108P 62/63 chevy 2 6 covair tempest rambler 6
Delco points A-112 46-52 Willys 1/2 set
Delco wheel cly kit 5455855 Buick 56-63 caddy 56-58 62-63 olds 59-63
Autolite plug A82
8 Autolite plug ARF52
8 Autolite plug AL7
9 Autolite plug AG42
10 Autolite plug A7
4 Autolite plug BTF31
10 Autolite plug AL82
9 Autolite vac advance 6-034
STD vac advance vc57
Autolite vac advance 6-207
Autolite vac advance 6-025
STD vac advance vc127 52-54 Henry J 2 Std vac advance vc121 42-50 olds 3 Autolite dist cap dh-79 41-42 ford 8
Autolite points 1-042 dodge hudson stude packard hudson
Autolite points 1-45v checker hudson kiaser brockway diamond t 5 Autolite points 1-40v dodge chrysler plymouth desoto imperal 2 Autolite points 1-303 dart imperal lancer valiant
Autolite points 1-046 dodge minneapolis moline desoto 2 Autolite points 1-46v same as above 3 Autolite points 1-045 fwd stude ac cris craft star ji case m-f
Autolite points 1-45v same as above 2 Autolite points 1-211 chevrolet covair
Autolite points 1-207 ih case mm oliver 3 Autolite points 1-212 gmc chevy 2 rambler tempest 4 Autolite points dp-4 ford 52-55 ford truck
Autolite points dp-5 54-56 ford mercury products 3 Autolite points 1-208 gm kiser nash packard willys 3 Autolite starter switch 333 29-37 chevy 3 Autolite gen cutout 333 26-34 29-31 chevy
Autolite rotor 4-208 gm ihc white
Autolite
1-043 chrysler dart desoto nash
Autolite condensor 2-042 dodge chrysler plymouth desoto imperal
Autolite condensor dc-2 ford lincoln mercury
Autolite condensor 2-206 reo white ihc olds nash 9 Autolite condensor dc-6 ford comet 2 Autolite condensor dc-12 edsel ford fairlane 4 Autolite condensor 2-207 chrysler chevy2 chevy pont 6 Autolite condensor 2-206 hudson nash 2 Autolite condensor dc-13 edsel ford fairlane comet 2 Autolite condensor 2-044 willys chrysler products 3 Autolite rotor dr-1 mustang comet edsel lincoln 2 Autolite points 1-041 dodge truck chrsler prod
Autolite points 1-214 autocar walter 3 Autolite gen brushes 11-203 gm packard ac ji case cat jd ihc mf mcdeer mm 3 Autolite condensor 2-032 checker stude continential hercules 3 Autolite gen brushes 11-205 ac ji case cat ihc mc deer oliver 3 Autolite gen brushes gb-8 falcon ford lincoln mercury
Autolite gen brushes gb-2 ford lincoln mercury
Autolite starter brushes 17-33 checker jicase coop cockshut mm oliver
Autolite Switch sw345
Autolite starter brushes sb-2 ford products
Autolite condensor 2-034 industrials
Shurhit voltage reducer vr-1
2 Napa Balkamp fuse 4-02294
Victor oil seal 46006
Moog
k3037
Allcar ujoint j5-121
Std brushes ex-145
std temp sending switch ts-10
std
ex-46
3 AC plug 44s
2 AC plug c45
AC plug 44
2 AC plug R46N
3 AC plug 45
Autolite plug A52
2 Autolite plug Btf6
4 Autolite plug BTF42
Autolite plug al82
Autolite plug A42
General under dash heater sw HS-600 6 volt under dash heater switch
Fram gas filter ca-6 box no lid 2 Hastings gas filter gf-12
Delco condensor F-202
Dole thermostat DV-1
std temp sending switch ts-2
Vulcan condensor FC10 hd
Delco repair wheel cly kit 5455856
Mallory condensor 25010 bad box
Robershaw thermostat 112??? no box
Fram gas filter cg-20bpl
???? ???? Poss chevy
Shurhit switch s-310
Vulcan points pm220
AC gas filter gf93
Pilot wheel cly kit 60-s gm 42-60
Fram gas filter g9
Vulcan condensor fc 1
Robershaw thermostat 370-f
Wheel balancers bead wheel balancers 4-111 go on next to drum and balance wheel as u dr Champion plug 22
8 Champion plug rf-14y
14 Warner ac clutch 22762-12
std brushes rx-49m
std condensor rc-1
std condensor gb-110x vw bosh porche simca
