Doug in Maryland
The axle seal on the driver's side rear if my AA got loose from the axle housing and allowed gear oil to run all over the brakes on that side. (This is a '30 bevel gear rear.) While the axle seal looks OK (other than not fitting tightly into the axle housing, which is something that I can fix) the hub seal has a small nick in it. I have some NORS Ford seals that I could use to replace this one. However, they are leather and a bit stiff. Does anyone know of anything that can rejuvinate the leather or should I just go ahead and get new ones? I'd actually prefer to use the Ford parts, since in my experience, they tend to be of higher quality. But I don't want to use something that is essentially doomed to fail. And I really don't know how old these are - probably 40 years if they're a day.
Thanks for any suggestions you might have. I'm still trying to get the oil off the brake shoes, but I might have to replace the linings. Oh well, the good news is that at least this means I'm driving it
Doug
Doug
